Configures the Auto-peering overlay service database entries.
auto-peering | Specifies Auto-peering. |
one-config | Specifies changing the BGP Auto-peering OneConfig configuration. |
overlay | Specifies overlay database containing centralized EVPN information. |
add | Overlay add server. |
delete | Overlay delete server. |
server | Specifies the server. |
address | Specifies the IPv4 server address/ |
addressv6 | Specifies the IPv6 server address/ |
type | Specifies the overlay database type. |
bgp-rr | Specifies overlay database type BGP route reflector. |
id | Specifies the configuring the overlay database ID. |
id | Specifies the overlay database ID.
password | Specifies configuring the password for the overlay database. |
none | Removes the current password. |
encrypted | Specifies encrypted format for the password. |
password | Specifies the password/secret key. |
N/A.
The overlay database allows the VXLAN edge technologies to dynamically span across brown field networks. For BGP-RR the ID represents the AS number, and for Redis, it represents the port to connect to.
The following example configures the overlay database of type BGP-RR at "50.1.133.105" with ID "2000":
# configure auto-peering oneconfig overlay add server 50.1.133.105 type BGP-RR id 2000
This command was first available in ExtremeXOS 31.1.
